Home Made Twins
Old May 24, 2008 | 03:50 PM
AF1CUMMINS's Avatar
Default Home Made Twins
If a man had a turbo off a piece of heavy equipment and wanted to use the factory turbo to do a home brewed twins set up, is there any reason it wouldn't work? Or should I just bite the bullet and cough up the $3500-$5000?
Old May 24, 2008 | 04:10 PM
2500HeavyDuty's Avatar
it could work, if your good at welding.
but you have to worry more about being able to spool that turbo up and not blowing any head gaskets.
Old May 24, 2008 | 06:47 PM
2001shrtbedcummins's Avatar
What turbo did you have in mind?
Old May 25, 2008 | 05:03 AM
AF1CUMMINS's Avatar
Possibly a '91 model John Deere 644 Loader, and if reference to the other comment, I know about the head gaskets. I'd probably have to have the head fire ringed. But u don't think the stocke turbo would be enough to spool it?
Old May 25, 2008 | 06:34 AM
Um...any markings on the turbo as to what it is?
Old May 25, 2008 | 09:44 AM
it really depends on wha size ti is, u can spool it, but itl probably be one hell of a ride when it lights up
Old May 25, 2008 | 02:49 PM
Old May 25, 2008 | 06:01 PM
Uncle Bubba's Avatar
Your talkin about a pretty advanced do it yourself project here. Not somethin for the normal mortal man. Sounds easy but there are a lot a little fine point details that go into not only building this setup but then being able to tune it all right to make it work.
Old May 25, 2008 | 06:42 PM
There is definitely some tuning to be done, but I'm still trying to found out what this mystery turbo is.
Old May 25, 2008 | 11:03 PM
HOTMOPR's Avatar
Could be a T04E45.. Whatever that is..
http://www.btnturbo.com/catalogue/BTN_Cat_2008.pdf
Here are some John deere part numbers you should find on the turbo. If its on of these its the turbo I listed above..
RE36037
RE31259
RE31258
