newbie here from pa!!! diesel=interesting
Old Dec 24, 2015 | 10:16 PM
greg12t's Avatar
Default newbie here from pa!!! diesel=interesting
Ok lets start with this ,thanks for letting me join and I will try to search all my questions before asking as i see some don't do that. I have a 2008 gmc with a 5.3 and was using it to tow my 24 ft enclosed race trailer ( I race micro sprints). While my truck was out for inspection i borrowed a friends 2000 dodge 2500 diesel,well that was all it took and just had to have one!! So after looking around for several months and was very shocked to find a 98.5 to 02 Cummins that had a **** ton of mileage and half rotted out selling for 10 G and up and just couldn't see spending that on something that I wasn't impressed by but I kept looking. So what I found and purchased was a good solid clean 2001 2500 sport with 200,000 on it and was stock with no upgrades but a 5in exhaust and A k&n factory filter upgrade.The guy was straight up front and said it had issues and me being very mechanically handy I figured how bad could it get !!! I wheeled and dealed with this gentleman and purchased the truck for $4000.00 and knew it needed help,so the problem it had was when you put it in reverse or drive it would shut off but didn't lunge like a locked converter,5 psi fuel pressure and would stay in 3rd gear unless manualy shifted and had a 2nd gear slip.I hooked it up to my snap on scanner and found it had the death code for timing control module,apps,low voltage to ecm.I put a reman H.O vp44 in it,adjusted the bands in trans and had to put an apps in it and also i replaced a stock lift pump. Now all is well and the truck runs great other then today I tried the 4x4 and it worked but didn't want to unlock so that will be getting looked at here relatively soon. all in all I don't think I made a bad deal and will post pics when I can, Thanks for reading Greg
Old Dec 24, 2015 | 11:12 PM
RedChevy44's Avatar
Welcome!
Old Dec 27, 2015 | 10:58 AM
Ohiocummins99's Avatar
Had something similar happen to me on a 94 12valve I had it was vacuum lines they were old and broke I would say process of elimination start with tracing the vacuum lines if they are not bad it could be the module on the passenger side of the front end let me know
Old Jan 5, 2016 | 04:56 PM
jkidd's Avatar
Welcome, there is a ton of knowledge here on the forum.
