Juice Attitude
Old May 24, 2008 | 12:49 PM
sst5606's Avatar
Default Juice Attitude
My Fuel pressure reading on my juice is 0 going down the road and 3 at idle. It seems to be running fine. Any suggestions? It is a stock lift pump.
Old May 27, 2008 | 07:52 PM
dukeboy_318's Avatar
id replace that lift pump, when i had my 98.5 with the edge juice with attitude, it done the same thing, ended pu being the lift pump, i was an idiot and replaced it with one from autozone for 150, burned it up too in less the 5000 miles, replaced it again since ididnt have the money for a fass, that was in april, my brother now has that truck and the pumps going out again, moral of the story, go with a fass or airdog, you wont be disappoint and you'll save that $$$ injection pump.
Old May 29, 2008 | 03:51 PM
E2theRock2's Avatar
I have had no problems with my Edge hot juice. I dunno, i put a lift pump on mine pretty quick and the only problem i have had with it so far is that it wouldnt go into the sixth setting so called Edge and they told me to put the code in again and wala is worked.
Old May 29, 2008 | 03:57 PM
how much faster is it on level 6 E2??
Old May 30, 2008 | 12:07 PM
jeepme79's Avatar
How do you get the fuel preasure display on the Attitude? Do I have an older version?
Old May 30, 2008 | 12:29 PM
E2theRock2's Avatar
It'll chirp the 35s on level six with out the other chip stacked no problem and it fuels real hard..... BIG clouds of smoke and it gets louder. I love the Edge its so bad ***. To get the fuel pressure reading you go to menu and then display settings and it has a list of what you can have on the display, at least on the newer ones, i have never used an older one
Old Jun 2, 2008 | 11:05 PM
mightydodge's Avatar
there are some options that are only available to the 06 and newer. us with 05 and older just have to suck it up
Old Jun 4, 2008 | 10:16 AM
my 99 has the edge juice with attitude and the only difference between it and the 05 and newer is that it doesnt display clutch slipage, load percentage, fuel rail pressure. it should show what your fuel pressure is though, even the first models out did that.
cass_epp
Wanted To Buy (WTB) - Used
Mar 20, 2017 04:07 AM
billy_2tone
For Sale
Jun 2, 2015 06:29 AM
stewart.william.c
Feb 11, 2015 01:39 AM
Kfohne21
For Sale
Dec 23, 2014 04:17 PM
LawdawgSHPD
Dec 6, 2014 06:24 PM
