5.9 cummins no low end power
Old Dec 8, 2015 | 02:48 PM
Grandpa Rat 409's Avatar
Default 5.9 cummins no low end power
I just did a in frame overhaul on a 5.9 Cummins in a 97 single axle dump truck. The truck is weak on bottom end when it hits 2400 RPM it comes alive. But when you shift the RPM drop back to below 2400 and runs like a dog again. I Just pinned the pump and the front gear so everything is in time. I was wondering about the android valve on the pump which is fed by the turbo boost. I haven't checked the boost yet to see what its doing at what RPM. Is there any Information on what the boost should be at what RPM? Anyone had this problem before or am I barking up the wrong tree?
Thanks Grandpa Rat 409
Old Dec 9, 2015 | 12:41 AM
two1racing's Avatar
could definitely dial some preboost fueling in to get so ***** in the bottom end
Old Dec 9, 2015 | 09:56 AM
Slim Whitey's Avatar
Boost should peg about 17psi max under load when stock.
Cruising down the highway at 1800rpm in OD unloaded should be about 5 psi.
Old Dec 9, 2015 | 02:02 PM
94 12valve's Avatar
check to see if the waste gate is stuck open.
