5 speed or 6 speed
Old Dec 7, 2015 | 02:31 PM
logan lacey's Avatar
Default 5 speed or 6 speed
Hey guys I just bought a 95 cummins stick with an auto trans. Looking for some input. Is it worth it to put a six speed and in? Really been thinking about it!
Thanks logan
Stock not stick
Old Dec 7, 2015 | 04:06 PM
Slim Whitey's Avatar
For the sheer hassle that is an nv5600 swap, I wouldn't bother. An nv4500 bolts right in, has a similar low range, and a similar OD.
The extra gear is actually placed between 3rd and 4th gear. The nv4500 has a fairly wide gap between 3rd and 4th, it something like a 35% rpm drop.
To solve this, NVG put a gear between the two in the 5600.
For what you get, and since the 4500 is such a widely known quantity, I'd just bolt in a 4500.
Old Dec 7, 2015 | 04:19 PM
Do you know about the load difference? Pulling hay and equipment? Still the nv 4500?
Thanks!!!!
Old Dec 7, 2015 | 04:53 PM
The nv4500 has a gvw of 19000 pounds I believe. Which is in excess of what the gvw of the truck and hauling limits are. A 1 ton from the 90s was rated to tow perhaps 12000 pounds. And the truck weighs 7 as it is.
The 6 speeds had a higher gvw yes, but you are still limited to the rest of the truck, and what it was certified to pull.
As for operation under load, there's not much difference. The 4500 is a strong unit if serviced correctly.
Old Dec 7, 2015 | 04:56 PM
Thanks for the info slim!!
Old Dec 7, 2015 | 11:09 PM
Tanman_2006's Avatar
With the correct oil, external coolers, and 25k oil changes they last a long time. In my experience.
Old Dec 7, 2015 | 11:56 PM
wildhorsemfg's Avatar
in a truck with 410s , a 6 speed is near worthless .. now with 355s and pulling 15k + its quite handy to have closer splits on gears ..
