Cylinder
Old Nov 26, 2015 | 11:17 AM
logan lacey's Avatar
Default Cylinder
Hey guys I have a 95 all stock. A kid at a diesel shop I know was putting in nozzles and after he did the 3rd cylinder wouldn't fire. I thought maybe a bad nozzle cuz I didn't have them pop tested. So I put the stock ones back in and it's still doing it. It ran fine before. When I crack the line on number three, fuel shoots out and the others don't.
Old Nov 27, 2015 | 05:39 PM
94 12valve's Avatar
did you bleed all the injectors after you swapped sets?
Old Nov 27, 2015 | 06:01 PM
Yes it takes a while to start but when it does its really rough and when I crack the line on that injector the motor pitch does not change and it squirts fuel out and the others just do a little bit of fuel. Like it has a flow restriction or plugged
Old Nov 27, 2015 | 06:05 PM
94 12valve's Avatar
I would recommend sending the injectors to get pop tested and gone through
