01 24v died air in the lines ?
Old Nov 23, 2015 | 08:31 PM
Bois1's Avatar
Default 01 24v died air in the lines ?
Well I lost I have a 01 dodge 24v I have the edge up on 6 have an air dog 150 ,cold air ,horn ,120 injectors , stock vp pump and recently installed duel disk south bend clutch .after installing the clutch some how when I put her to the wood smoking out some hot shot ricer I shift and the truck dies . Air in the fuel don't know how but has happened twice now .hoping someone else has an idea what is happening
Old Nov 23, 2015 | 10:35 PM
staylorw250's Avatar
Do u no what kinda fuel psi it has when it's dieing
Old Nov 24, 2015 | 05:55 AM
gh0stman's Avatar
If you let off the pedal quickly after a full throttle run you will push air into the injectors causing it to vapor lock. You will have to bleed the air out of the injectors. Next time don't let off so quickly and you wont have that issue.
How many miles have you put on your SB? I wouldn't be doing any high speed running till the 500 mile break in period is up.
Old Nov 24, 2015 | 03:37 PM
Bois1's Avatar
I'm 16 at idle 15 running and 14 at full throttle. Ghost man I think the vapor lock is exactly it I had to bleed the lines last time .other than not letting off so fast could there be anything else to fix to stop this from happening ? And I did the 500 miles of hell with the sb
Old Nov 24, 2015 | 05:10 PM
gh0stman's Avatar
I feel your pain on the break in. I went from 47re to the sb3250. Big change. Other than letting off slowly there is nothing I know or have heard.
Old Dec 10, 2015 | 09:06 PM
Jose the roofer's Avatar
Where is the vacuum pump located and what is its function also my 2002 ram 24 valve cummins is leaking oil from a hose that hungs down at the front right of engine driver side what can that be or can that be fix?
Old Dec 10, 2015 | 10:40 PM
Bois1's Avatar
Well Jose the roofer the vacuum pump is on the right front of the motor conected to the power steering pump .it's job is to make vacuum for the motor . The tube that is leaking oil is your breather tube either you put a catch can in or splice in to the tube and run it back so it dont soak the motor down . And last but not least this thread is about air in the fuel lines .
