VP44
Old May 22, 2008 | 10:52 PM
dieselsmoke74's Avatar
Default VP44
what fuel psi can a vp44 handle, and what does an airdog 150 produce?
Old May 22, 2008 | 11:03 PM
Uncle Bubba's Avatar
The VP44 will be fine if it never goes below 5 psi and never more then 20 psi. Depending on who you talk to this may vary 1 or 2 psi in any direction.
I'm pretty sure you can adjust the Air Dog or FASS to operate at your desired pressure.
Old May 22, 2008 | 11:08 PM
what would be the desired pressure
Old May 23, 2008 | 12:34 AM
That depends on who you talk to. Personally I have mine set up to hold 18psi at all times.
Old May 23, 2008 | 05:05 AM
DB Admin's Avatar
Banned
Im running ~20 PSI with the Air Dog its adjustable tho
around 15 psi is ideal , im just too lazy to turn mine down
Old May 23, 2008 | 11:26 AM
Mr.Krabs's Avatar
Mines around 15psi,made it over 200k on my last VP.
Old May 27, 2008 | 06:19 PM
dukeboy_318's Avatar
my fass 150 gph idles at 16 psi and under full throttle it drops to 12-13 when ive got my edge turned up. if i were you, id look at getting the new adjustable one from fass, you can adjust that thing anywhere from 15 to 45 psi!
Old May 27, 2008 | 08:31 PM
Stangpwr71's Avatar
Ive ran over 23psi in my vp44 for over a year with no issues, but then again i am trying to swap in a p-pump
Old May 31, 2008 | 01:32 AM
justviper1's Avatar
i am in the market for a new injection pump mine is slowly dieing. is there a way to switch to the p-pump? anyone have any good prices on a VP44?
Old May 31, 2008 | 06:48 AM
stkdram55's Avatar
yeah there is a way to convert, you have to change your front gear cover from a 12 valve get custom injector lines made, and some people say you'll be alright with with your original injectors but its better to have at least 90's or you'll pop your injector lines, i also think you have to get the gear from the 12 valve to run the pump, oh yeah and dont forget the pump. theres probably some things im forgetting but that short of it
