Electrical problem
Old Nov 18, 2015 | 08:50 PM
casper83's Avatar
Default Electrical problem
I have a 96 12 valve and my tach doesn't work, no charging system, and the transmission won't shift out of second gear. I have been told that the pcm is bad. I have read that the pcm is also the most unnecessary replacement on that year model. I have also read that my crank sensor could be bad. Is there any tests I can do to make sure I don't have to fork over. 400 bucks for a pcm for nothing. Thanks in advance.
Old Nov 19, 2015 | 04:12 AM
Jet A Fuel's Avatar
If your voltage is below 12 volts the PCM won't work but here are a few checks and some ideas.
To check the PCM do This : disconnect your crank sensor, turn the key on, check the harness side Blk/Lt Blu wire for ground (low Resistance). Check PPL/Wht wire for 5 volts DC. If these check good chances are your PCM is fine.
To check the sensor do this; check resistance at Crank sensor pig tail (Unplugged still) between PPL/WHT and Blk/LT Blu should be some resistance showing and not a open circuit.
Here are some schematics to help you out.
1996 engine schematic1.pdf
1996 engine schematic2.pdf
1996 engine schematic3.pdf
Old Nov 19, 2015 | 05:12 AM
casper83's Avatar
Thanks for the reply. I'll have to try that out this afternoon when I get in from work. I'll repost after.
Old Nov 28, 2015 | 08:18 PM
casper83's Avatar
I found my problem right off the bat! The plug for the crank sensor had vibrated loose. However, now I can drive it, but when I go to stop, my transmission won't shift itself out of gear. I have to shift it into neutral and then back in drive. I pulled the pcm out at one point. Could that have caused it? At one time there was a lockup switch on the truck but everything has been disconnected. TIA
Old Dec 7, 2015 | 03:54 PM
casper83's Avatar
Anybody?
