12v pump question
Old Nov 16, 2015 | 02:02 AM
cummins Pride's Avatar
Default 12v pump question
I pumped up one of my 12v cummins (180hp pump) in all I did was a #0 fuel plate wide open, afc housing wide open boost elbow but did not mess with this little so called "smoke screw" on the back of the housing. Will that effect my power output at all?
As in would I get more power out of her if I mess with that smoke screw?
Old Nov 16, 2015 | 05:16 AM
94 12valve's Avatar
No you will not get any power
Old Nov 16, 2015 | 12:11 PM
Just smoke which I don't want?
Old Nov 16, 2015 | 12:45 PM
South Tx Coal Roller's Avatar
These will get you squared away.
afc mods (lots of pics) - DieselRam.com
[url=http://www.cumminsforum.com/forum/94-98-performance-parts-discussion/312241-afc-tuning-explained.html#post3293034[/url]
Old Nov 16, 2015 | 04:07 PM
94 12valve's Avatar
The screw your talking about is called the pre boost screw. It is used as a fine tuning tool for your AFC. As the name says all it will do is add more fuel before boost is made.
Old Nov 17, 2015 | 12:43 PM
Okay, thank you, can I be sacrifing much performance of spool up not moving it.
Old Nov 17, 2015 | 02:21 PM
With proper adjustment you can have faster spool up and less lag. It's all explained in the links I posted.
Old Nov 17, 2015 | 04:15 PM
94 12valve's Avatar
When you say your AFC is "Wide Open" what exactly do you mean?
Old Nov 18, 2015 | 12:51 AM
The starwheel is maxed out and the afc housing is full forward.
