Just another lift pump question
Old Nov 12, 2015 | 10:22 PM
staylorw250's Avatar
Default Just another lift pump question
I bought a fass 150 and am planning to put it n this Saturday so I was looking around for tips and tricks and was surprised to c nothing but 1/4 tank issues so my question is there ne way to modify the fass draw straw to work good or am I out more money buying a different draw straw!?!
Sorry 4 opening another thread on this but after an hour of looking Iv got a headache from my phone screen
Old Nov 16, 2015 | 05:33 AM
gh0stman's Avatar
As long as you make a straight cut you shouldn't have any issues. Also if you installed a sump you shouldn't have any issues either.
Old Nov 16, 2015 | 08:43 PM
Well I started to go with the draw straw but didn't find a place that had clearance or it would have been in the very front or rear and I wasn't taking chances on the 1/4 tank issues so I siad to heck with it and bought a sinister diesel sump
Umm idk if I should start a new thread but the fass fitting won't work with my edge fuel pressure sensor.... Is there ne place I can buy one or do I just need to piece something together
And second does ne1 run the fass 150 and a sump I'm curious what would b good to run my fass return
Old Nov 17, 2015 | 05:12 AM
gh0stman's Avatar
You can get a push fitting and mount in the line. I don't have the draw straw but if you don't have the in-tank lift pump you can probably get away without it. But from what you have bought you should be set up to run no problem.
Old Nov 17, 2015 | 12:51 PM
It has the in tank pump and so a t fitting close to the pump will work fine!?!
Old Nov 17, 2015 | 01:01 PM
gh0stman's Avatar
Put in a push lock fitting about a foot back from the VP will work just perfectly. That's where mine is located.
XDP Push Lock Fuel Pressure Tee XD200
Just make sure you get one that matches your hose ID.
Old Nov 18, 2015 | 07:12 AM
Jet A Fuel's Avatar
I wonder if he will need a snubber for the pressure transducer?
I have heard some people say it eliminates fluctuations and at 200 dollars for an autometer sensor its good insurance, a lesson learned the hard way for me.
Old Nov 18, 2015 | 07:14 AM
gh0stman's Avatar
Snubber wouldn't hurt but it looks like he has the EJWA which has a fuel pressure gauge built into it. No since in buying a new one when you have one already.
Old Nov 18, 2015 | 07:16 AM
Jet A Fuel's Avatar
here are some other links too....
HPFP-95-1001Installation.pdf
https://www.dieselbombers.com/98-5-0...p-install.html
https://www.dieselbombers.com/tech-a...-part-1-a.html
https://www.dieselbombers.com/tech-a...-part-2-a.html
Old Nov 18, 2015 | 07:28 AM
Jet A Fuel's Avatar
If you have time and can take some pictures and do a write up on your install it sure is needed. I have noticed there is a lack of threads that still contain the pictures from the previous owner and old timers of the website.
