Cruise control woes
Old Oct 22, 2015 | 08:36 PM
staylorw250's Avatar
Default Cruise control woes
The cruise control light does not come on I changed the switch and that didn't help from what I can tell this truck has and ecm controlled cruise instead of vacuum controlled cruise regardless all blower positions work(no broken vacuum lines&#128513
This truck is an 02 3500 4x4 6speed manual any help or points n the right direction would b greatly appreciated
Old Oct 22, 2015 | 10:14 PM
Jet A Fuel's Avatar
Any ABS light or codes?
Old Oct 23, 2015 | 05:35 AM
gh0stman's Avatar
could be the clock spring in the steering wheel.
Old Oct 23, 2015 | 10:24 AM
Idk bout codes I'll c what the smarty says later
How do I go about checking the clocks spring?!?
Old Oct 25, 2015 | 10:51 PM
Well I plugged the smarty n today and she didn't have ne codes stored n her
Do I prolly need to 2 look n2 the clock spring ?!?!
Old Oct 26, 2015 | 06:23 AM
gh0stman's Avatar
I have heard people having issues with the clock spring not letting the cruise kick on. How to change it out I don't know but I am sure there are a few write ups on google.
Old Oct 26, 2015 | 07:02 PM
kryz9903's Avatar
Sounds like the clock spring. It's located in the steering wheel column. Does your horn work?
Old Oct 29, 2015 | 10:11 PM
Yea the horn works just fine.. And can the clock spring still b bad even tho no airbag lights or on
Old Nov 3, 2015 | 06:10 PM
kryz9903's Avatar
Yes it can still be the clock spring even without any air bag lights.
Old Nov 9, 2015 | 10:57 PM
Found my problem it was a broken wire right at the plug in where my tilt steering tilts not bad once I got all the plastic off thanks for all the advice guysCruise control woes-image.jpeg I hope y'all can c the picture gonna get some solder tommorow and then on with the fass install��
