1995 Tahoe brakes
Old Oct 22, 2015 | 11:40 AM
jrsavoie's Avatar
Default 1995 Tahoe brakes
1995 Tahoe brakes
I pulled the front wheel on the Tahoe and the brake pad on the inside was wore down.
I noticed it was not braking properly the last time I drove it. the braking felt weak.
Is this a caliper issue? A slide issue? A flex line issue?
Or should I just replace The caliper, pads and flex line?
If so are there recommended parts to use?
Old Oct 22, 2015 | 04:37 PM
Mayhem's Avatar
Originally Posted by jrsavoie
1995 Tahoe brakes
Sounds like a slide issue whomever did the brakes last more than likely did not clean and grease the slides push them out grease them with some new pads I prefer Wagner brand but Brake best select from Oriely's aren't bad for the money.
