Help with parts list
Old Oct 10, 2015 | 05:13 PM
dcarter96's Avatar
Default Help with parts list
Hey guys, trying to figure out if I was missing anything. I talked to diesel auto power the other day and built my parts list and I figured id see if you had anything to add or change. I was told id be making roughly 750 hp I don't know how true that is but just trying to make sure everything is right before I have it shipped to my door. thanks in advance. I will be going with the new Quadzilla programmer and a Fire punk trans rated for 800hp.
here is the list
ARP Custom Age 625+ - 247-4204
BD Diesel Super B Special 64/71/14 Turbo Only
Borg Warner S475 - 75/96/1.32 T6 - S475
Bosch Hot Rod VP44 Fuel Injection Pump 40-100HP
Crazy Carl's Twin Turbo Kit - TwinTurboKit
Diesel Auto Power350HP Performance Injectors 7x0.014 SAC - VP7X14SAC350
Diesel Auto Power Assembled 3-Piece T3 Exhaust Manifold PyroTapped With Gaskets - 24VT3M
Diesel Auto Power Extreme Duty Pushrods 4340 Chromoly7/16" .120 Wall - 24VPR120
Fass 220 GPH FlowRate Titanium Series Includes Spring To Raise Pressure To 50 PSI - TD08220G
Hamilton Cams 188-220 Steel Cam - 07-C-188-220-108S
MaxSpool 24 Valve Dual Springs With Stainless Retainers -24VDS
Old Oct 11, 2015 | 09:24 AM
Jet A Fuel's Avatar
Sounds like some awesome mods!! I would recommend a draw straw kit for sucking the fuel out of the tank. Not sure if the Fass titanium series come with it
Old Oct 11, 2015 | 09:44 AM
dcarter96's Avatar
Default thanks
would you recommend the draw straw or the sump puck for the bottom of the tank?
Old Oct 11, 2015 | 11:16 AM
Jet A Fuel's Avatar
Never heard of a sump puck that's new to me. I would imagine that anything is better than the stock unit. I use a 1/2 drawstraw from airdog its simple and does the job well.
Old Oct 11, 2015 | 03:12 PM
dcarter96's Avatar
yeah the sump, pulls from the bottom and you don't have to drop the tank.
Old Oct 13, 2015 | 04:37 AM
gh0stman's Avatar
Get the sump. Forget the HRVP. Your edge and VP will not like each other. To much added timing. Save to money and get a SOVP. It will make greater power with the tuner.
Old Oct 13, 2015 | 04:38 AM
gh0stman's Avatar
Also, That FASS 220 has to much fuel pressure for the VP. It looks like it is for a P-pump. The FASS 150 will be all you need.
