View Poll Results: What turbo to go with on a built 12 valve
Built 12 valve turbo options??
100.00%
Turbo options
0%
12 Valve help
0%
Specific turbo?
0%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
What turbo to go with?
Old Sep 28, 2015 | 01:07 PM
Copenhagen Angel's Avatar
Default What turbo to go with?
Sorry if this is in the wrong place but I need to replace my turbo and am wondering what route to go. I have a 1994 12v cummins with a #8 fuel plate, 4 in straight pipe, 75 hp injectors, bored 40 over. Colt cams big stick, 60 lb valve springs, 3k governor springs and timing at 16.5. Has a 5 speed and full ceramic clutch. All of witch have been swapped into a 76 dodge powerwagon and it is intercooled.
My question is I have a hx35w and its passing oil. I was thinking of doing a hx35 hx40 hybrid when I rebuild it. I am wondering if this will be enough turbo to get me around 40 psi of boost. I have also been thinking on the lines of a s300 but not sure what sizes to go with for the best towing and spool time. don't really want to spend the money either. I don't want a lot of lag because I live in Colorado mountains and need to be able to stay in the power when I shift with a load. Or am I just needing to do a whole other turbo than I mentioned?
Old Sep 28, 2015 | 01:44 PM
94 12valve's Avatar
what are your overall power goals?
Old Sep 28, 2015 | 02:33 PM
To spoil up good with little smoke and about 40lbs of boost idk what that builds up to but I would think around 350 to 400 hp on a dyno
Old Sep 28, 2015 | 02:40 PM
I think I'm leaning for a s300 with the 63/68/14. What do you guys think about that?
Old Sep 28, 2015 | 07:19 PM
94 12valve's Avatar
tis a good choice IMO
Old Sep 28, 2015 | 08:31 PM
ok. any other turbos that you know of that are good for the application?
avatardvr
18
Aug 8, 2019 12:38 AM
n2brk
Feb 21, 2015 09:05 AM
jrsavoie
Feb 6, 2015 09:44 PM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
