Fuel gauge does'nt work.
Old Sep 27, 2015 | 02:15 PM
Steve123's Avatar
Default Fuel gauge does'nt work.
My fuel gauge stoped working so I pulled the fuel tank and the steel arm had come off. I have the arm back on
now and reading variable resistance on my ohm meter
but the fuel gauge is still stuck on empty. There is no voltage coming from the plug.
Thanks
Old Sep 27, 2015 | 05:22 PM
Steve123's Avatar
Smile
Correction, there is 5v between the 2nd and 4th terminal of the plug and if I disconnect the battery terminals and plug in the sender unit the fuel gauge will start to rise and then go back to empty until I disconnect the battery terminals again.
Old Sep 28, 2015 | 02:36 PM
Steve123's Avatar
Default Solved
The wire arm came off the variable resistor on the sender unit so I epoxied it back on so it can't come off again. I also found a severed wire on the drivers side under the door hinge area. Fixed wiring and fuel gauges works now.
Thanks to Dinner and espanton at Fuel gauge problem - not sender - Dodge Diesel - Diesel Truck Resource Forums
Dbleo351
Nov 20, 2016 09:34 AM
Cavnar
Sep 9, 2015 07:18 PM
ctjkelley
Jun 3, 2015 06:01 AM
gauge1325
May 3, 2015 01:33 PM
moneypitk5
Feb 12, 2015 11:01 AM
