Turbo shut off or got stuck
Old Sep 26, 2015 | 01:24 PM
bosse777's Avatar
Default Turbo shut off or got stuck
Tuesday I was driving home from a trip, on the way up a 6% grade at 70mph empty the turbo either shut off or got stuck for a second, then started spooling again, this happened twice about 2 miles apart, then when I got in to town I was going 35 and it cut out again... I pressed the accelerator hard, it shifted down and still no turbo( no smoke either) I pressed a bit harder it shifted down to 1st and broke the turbo loose and I had power again... this happened a second time a few blocks later... it has been 4 days and have only driven it 30 mi a day to work and back and have had no issues other than on tuesday, any help would be greatly apreciated, I think it's a berring? ..... oversized turbo, 100 horse injectors, both pumps done, edge chip, couple other things done also....
Thanks, Bosse777
Old Sep 27, 2015 | 09:17 AM
wildhorsemfg's Avatar
pull turbo inlet .. turbo should spin freely .. if tight .. a bearing may be buggered up
Old Sep 27, 2015 | 07:36 PM
bosse777's Avatar
Code; injector pump timing failure
Old Sep 27, 2015 | 07:37 PM
bosse777's Avatar
Spins clean, no play
Old Sep 28, 2015 | 05:38 AM
gh0stman's Avatar
If its a timing failure that would make since that it wasn't giving extra fuel to add boost.
camp9
Mar 25, 2017 07:40 AM
Aug 3, 2015 09:20 AM
Pstroker73
Jul 9, 2015 07:55 PM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
