1997 dodge 12v sticking throttle
Old Sep 24, 2015 | 10:01 PM
12vWoodHauler's Avatar
Default 1997 dodge 12v sticking throttle
Hello, I just purchased a 1997 dodge cummins. The throttle is rock hard and sticks at all positions. I have been spraying penetrating oil on the return springs and linkage with no avail. I did get the linkage to move fairly easy by hand, but will not return by itself from WOT or any position for that matter. Is there anyway to take apart the throttle system to clean and lube it to see it that will help?
Old Sep 30, 2015 | 07:58 PM
To answer anyone that has this same thing happen to them, it was the throttle linkage shaft sticking in the plastic sleeve. Had to pull apart the whole throttle linkage and remove the tps to get to the shaft. I then brake cleaned, and wire wheeled the shaft to make it nice and shiny again. Greased up the shaft and reassembled the throttle linkage. No more sticking throttle!
DBHX0311
Jun 19, 2015 11:57 AM
RedChevy44
Apr 21, 2015 05:47 AM
torino73
Apr 14, 2015 11:15 PM
krg3590
Mar 15, 2015 08:57 AM
Josh Chretien
5.9L 12V Performance
Mar 1, 2015 06:00 AM
