Turbo problems?
Old Sep 16, 2015 | 08:19 PM
huntman7's Avatar
Default Turbo problems?
So I've got an issue I think. I've got a factory stock turbo on my 12 valve. (Hx35) All stock except 4 inch straight pipe and slid fuel plate forward. My boost psi won't even touch 20 psi, and my egt's hit 1100 like nothing. I've got some shaft play but I'm not sure what's bad or good. Is it worth it to rebuild the stock turbo? Or to just buy a new one.
Old Sep 16, 2015 | 08:44 PM
Rustbucket's Avatar
Default Waste gait?
I'm not positive on this but I did run into the same thing with my 95 12v and theirs a line coming from the back of the afc. It's rubber for a few inches and then steel or aluminum to the wg. I plugged mine with a fitting and was easily able to run up to 40#. Probably not the best way to go but somewhere on here is a how to on building an adjustable inline plug to manually adjust it.
Old Sep 17, 2015 | 08:49 AM
huntman7's Avatar
This won't help my egts down though will it? I'm worried about wearing out my turbo even more hah
Old Sep 17, 2015 | 08:57 AM
Rustbucket's Avatar
Default I'd say yes
More fuel needs more air to burn clean. But on the flip side yes it could also wear much faster especially if you just plug the wg.
Old Sep 17, 2015 | 09:08 AM
wpg6.5's Avatar
Id personally suggest getting a new one especially if you want to and plan to add more power and fuel. Tons of options, I'm partial to bd's products since they have simple and cost effective kits for regular do it yourself guys that don't wanna break the bank or go super custom. Either the super b or killer b would suite your needs and probably final power expectations. And all the s300 bd turbos are the same price if I remember correct and include a new down pipe and everything to install it.
Old Sep 17, 2015 | 10:03 AM
Rustbucket's Avatar
Default Yep
He's right I just put a super b on mine last weekend. Really easy to install if you read the instructions. 3 to 5 days from thoroughbred diesel for 1300 bucks and install took maybe an hour. With a #6 plate and stock springs and injectors it doesn't spool well low rpm but comes in like a banchie. 4" turbo back and comes with a dp and stretch clamp.
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
n2brk
Feb 21, 2015 09:05 AM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
