Looking for more power
Old Sep 9, 2015 | 12:27 PM
cummins Pride's Avatar
Default Looking for more power
Already have a afe stage 2 intake with horn, big exhaust, 80hp injectors, #0 fuel plate, afc wfo, 4k gsk, mac plug, 60# valve springs, on a stock turbo in lift pump, what is the next step for power delivery valves or turbo first
Old Sep 9, 2015 | 05:12 PM
JBearSVT's Avatar
Turbo, definitely. DVs without turbo are just going to melt things. Although to make a turbo worth doing, you may want to step up to 150hp injectors.
Old Sep 10, 2015 | 12:50 AM
I am flowing a lot of fuel, no clue why i would need 150hp injectors. Delivery valves should make up for it... shouldn't it.
Old Sep 10, 2015 | 12:52 AM
Only going for a killer b turbo 63mm
Old Sep 10, 2015 | 05:00 AM
JBearSVT's Avatar
You won't need them, you'll just get more from a bigger turbo if you have them. You'd get more from it with DVs too, but more fuel without a bigger turbo is just going to spike the stock one way out of it's optimal range and make a ton of heat- unless you turn down the pump, which sort of defeats the purpose of adding the DVs or bigger sticks in the first place. You'll make more power with the big turbo at less boost than you will maxing out what the stock one can spin, and the stock one isn't making great use of the fuel you can flow already. Right now a better turbo is a good choice, more fuel mods not so much.
Old Sep 10, 2015 | 11:30 AM
94 12valve's Avatar
A bigger turbo would be the best choice of the two options you listed. What is your overall power goal?
Old Sep 10, 2015 | 11:31 AM
Do you have a recommendation for a good single turbo set up for 500hp
Old Sep 10, 2015 | 11:40 AM
94 12valve's Avatar
A 63mm to 64mm turbo can get you there but I would go with a bigger turbine than the killer B has. The 68 turbine has treated me well so far.
Old Sep 11, 2015 | 12:17 PM
I have studs and aftermarket head gasket, but should I do a super b special which is a 64mm, might still be having to tow and I know they say the 64mm is not a good turbo to tow with?
Old Sep 16, 2015 | 05:56 PM
wpg6.5's Avatar
63/68 of your choosing would be a good choice
May 10, 2015 10:57 PM
explorer197143
Dec 28, 2014 01:14 PM
