compression test
Old Sep 8, 2015 | 09:13 PM
russellflemister's Avatar
Default compression test
have a 1999 dodge 3500 24v cummins knocks very lour runs good otherwise no miss that I can tell I need to know how to hook up a compression tester up truck has a white cloud when reved up does have blow by out oil cap but doesn't start that till truck warms up a bit exhaust tail pipe is very wet doesn't smell like raw fuel truck is built strong has a o-ringed head with arp head studs only 158k starts right up sounds like a thrown rod but could be a melted piston GF got mad a towed my 20ft encloded trail with both four wheelers with my edge with attitude on LEVEL 5 up a long hill she clamed it only was making a weird noise need help
Old Sep 8, 2015 | 11:08 PM
Just-Another-Dieselguy's Avatar
The compression tester used for that engine will replace the injector.
Pull the lines and the valve cover off. Pull the feed tubes and one injector at a time and test the compression.
It is very hard for us to come up with a good diag without heading the noise.
Get back with some numbers and let us know!
Old Sep 9, 2015 | 07:55 AM
gh0stman's Avatar
Are you making oil? how does your oil levels look?
Old Sep 14, 2015 | 09:33 PM
No engine is not making oil (thank god) it still thick like new 15-40w does not smell of diesel
Jul 30, 2015 10:30 AM
May 20, 2015 11:20 PM
Nov 20, 2014 11:20 AM
Oct 16, 2014 07:10 PM
Oct 11, 2014 06:25 AM
