cummins 1994 with 1998 12v engine problem!
Old Sep 7, 2015 | 07:13 PM
jeremy01995's Avatar
Default cummins 1994 with 1998 12v engine problem!
hi, i have a problem with my 1994 ram cummins with 12v 1998 engine.
this is a video of the problem.
with hose
fuel shut off removed: same problem( so the fuel shut off is good)
fuel filter and prefilter is new.
new tork tek overflow valve.
new hose from the tank to lift pump.
in tank module is good.
same problem with hose dorectly in a jug of fresh fuel.
did the return flow is suposed to be constant or like *pulse*?
it didnt do it until temp is at 180...
tanks for help!
Old Sep 14, 2015 | 06:34 PM
when i run, between 1500-2000rpm the fuel pressure goes up and down...( between 5-40psi) non stop...
NO LEAKS, NO AIR LEAKS. it do it with a hose direclty from a jug of fresh fuel to the lift pump.
burndiesel
10
Feb 7, 2023 01:15 AM
Antwhite19
Mar 26, 2020 04:58 PM
Jonrarick
Oct 25, 2016 01:32 PM
Oct 30, 2014 08:10 AM
Omingnome
Oct 20, 2014 12:25 PM
