chiping My 2001 5.9 227.+miles
Old Sep 3, 2015 | 04:54 PM
mpcampers's Avatar
Default chiping My 2001 5.9 227.+miles
thinking about installing a chip in My 2001 dodge 5.9 diesel, motor has 50k miles , truck has 227+k on it. I need a little more to tow our fifth wheel. Had 50 over injectors in but took them out to much smoke on and in the trailer. but had good towing power. will a chip be a bad thing for the miles on the truck we use it as a DD also. thanks ..
Old Sep 4, 2015 | 06:32 PM
lukesdiesel's Avatar
I would go with something like an Edge EZ to help add some power for towing without adding much smoke.
Luke
www.dieseldawgs.com
Old Sep 6, 2015 | 10:08 PM
mpcampers's Avatar
I am looking at a Superchips 3842 Flashpaq Computer Chip Programmer it looks like it has a lot of setting and can be set back to factory and may be good for other makes and models down the road. Just afraid of trashing my trans.? but I will take a look at the Edge EZ .
thanks Luke
Old Sep 7, 2015 | 01:01 AM
Flikkie2001's Avatar
I got a superchips on my 01 it's alright just always on towing mode gained a few mpg buddy swears by his edge ez and he's running 327k on a 01
Old Sep 7, 2015 | 08:28 AM
mpcampers's Avatar
I am ok with the way it runs now I just need a little more for towing, and I trying to keep the price down. not planning on keeping it long I really need a dually. I am towing a 39ft fifth wheel.
Old Sep 10, 2015 | 09:24 PM
tbirdz24v's Avatar
Go with the Edge. I had the superchips in my truck and hated it. I then bought the Edge EZ. I love this chip. Makes good power. I've never had any issues with a lack of power to haul. Gave me some better fuel mileage as long as you're not wide open throttle all the time. I brought a car back from Indianapolis to Pittsburgh. Drove between 70 and 75 mph the whole way back and got around 17 mpg out of it. Heading out to get the car was around 20.5 with an empty trailer. They are decently prices on amazon. Also found with the superchips in my wife's truck it gave here a trans issue also. Changed the programmer and it went away. Not a big superchips can since then.
Old Sep 12, 2015 | 08:45 AM
mpcampers's Avatar
been checking out the Edge. think I am going one. took a look at amazon and found prices about the same as the superchip.
Had to replace My raptor 100? it just stoped working. don't know? would prim the filter but after that nothing, I think the pr valve went bad.
Old Sep 13, 2015 | 07:59 PM
tbirdz24v's Avatar
Mine and my wife's trucks both had that issue. Couldn't find the problem. I just took the relay out and put a jumper wire in the relay block. They've been working fine since.
Old Sep 14, 2015 | 12:28 PM
mpcampers's Avatar
where would I find the relay, is that on the pump. I have never taken the pump apart..
Old Sep 18, 2015 | 01:30 PM
tbirdz24v's Avatar
Mine is on the firewall next to my clutch master cylinder. There should be wires running from the battery, into the engine harness, and to the pump from the relay block. I'm trying to attach a photo of the way I have mine setup. I can't figure out how to post it to the thread but if you look on my profile under the pictures in the album titled " my truck " I was able to post them in there.
