98.5 cummins 64mm dtech?
Old Aug 30, 2015 | 03:05 PM
Craigdegolier's Avatar
Default 98.5 cummins 64mm dtech?
I got a dtech 64mm turbo from a buddy and was thinking about putting it on my truck. I am runing the stock hx35 currently and can get 34lbs of boost max, any benifets of putting this on my truck? Thank u for any help
Old Aug 31, 2015 | 06:12 AM
gh0stman's Avatar
What size injectors are you currently running? If its the stock injectors it will be very laggy. A 64 out of the box is already laggy but without the fuel to push it it will take longer to spool.
Old Aug 31, 2015 | 11:10 AM
It has stock injectors, if I want to run that turbo someday what size injectors would be the best for it? Or what can I do to not have the lag? My stock hx35 spools nice and quick but I want more boost and power. Thank u
Old Aug 31, 2015 | 11:14 AM
gh0stman's Avatar
Do you have the full specs of the turbo?
Old Aug 31, 2015 | 11:39 AM
Old Aug 31, 2015 | 12:08 PM
gh0stman's Avatar
This might get you closer to the answer you are looking for.D-tech 64/65/12 - Dodge Cummins Diesel Forum
Old Aug 31, 2015 | 02:51 PM
I basically got it for free and am getting the upgraded turbine shaft with the rebuild kit, I might try it when I do injectors, what size should I run to complement the turbo
Old Sep 1, 2015 | 05:00 AM
gh0stman's Avatar
I would run some 150hp. But I am not am expert in matching turbos or injectors. I would recommend calling the turbo manufacturer as well as a injector manufacturer. See if their recommendations are the same. That will get you the best answer.
Old Sep 5, 2015 | 03:10 PM
lukesdiesel's Avatar
150hp DFI injectors would work good with that Turbo setup. Let me know if I can help
Luke
Renteria1217
For Sale
Aug 16, 2015 09:43 PM
gd1996
For Sale
May 15, 2015 09:42 AM
97boatstroke
Dec 22, 2014 09:54 PM
LawdawgSHPD
Wanted To Buy (WTB) - Used
Dec 6, 2014 06:24 PM
Oct 24, 2014 04:40 AM
