2005 F350 6.0 Starting/Running Issue
Old Aug 30, 2015 | 07:20 AM
Ric Stokes's Avatar
Default 2005 F350 6.0 Starting/Running Issue
Gentlmen, First off ,thanks for letting me join... Been a lurker here for a while but now I have some specific issues. A few weeks ago while idling I noticed a "hitch" in the motor idle , it did it twice and when I got in the truck I had no pedal... Idled fine but no pedal response. Changed out the ICP and harness but still had issues with it dying out. Replaced the IPR (screen was sucked in a bit) and that seemed to clear it up. After a few days when I start it, it has a rough idle but after I run it a bit it seems to run fine and will idle ok. ( a friend did scan it while missing and it showed #6 injector going in and out) . Anyway last week while on the highway doing 70 I noticed a little surge and buck then it went away... Someone suggested that I might have a little stiction going on so changed the oil and added some AR 9100 ... Since the oil change Ive made two 80 mile round trips and each time on the way back its bucked for just a second then it runs fine. Last night after heading home I stopped by the store and it was idling fine...shut it down for probably 10 min and when I came out it didnt want to start. Had to crank it for a bit ( 3 times) then it fired up. Drove home and it was fine. Tried to start it this morning and it cranked and fired right up with the rough idle then died. Cranked it four or five times and wouldnt fire. This was 5 am and didnt want to wake up the neighborhood so I took the car in. When we scanned it the FICM voltage was fine, Im at a loss .... Any thoughts? Thanks in advance...Ric Sorry for rambling but wanted to give all the info I could think of..
Old Aug 30, 2015 | 01:16 PM
Ric Stokes's Avatar
Default ?
Awful lonely in here....
Old Sep 11, 2015 | 01:29 PM
Fordman191876's Avatar
Go to you tube and search Diesel Tech Ron! He is one of the best, and if you don't already have one, go to Auto Zone and buy yourself a Scan Gage 2. They are around 100 dollars and worth every cent. You can go to their web site and print out all the information you need to program it. Mine has saved me a lot of money. I heard about it from Diesel Tech Ron.
Cavnar
Sep 9, 2015 07:18 PM
Ric Stokes
Aug 31, 2015 06:58 AM
Cavnar
6.0L Performance
Apr 7, 2015 10:35 PM
jordanokc
Feb 8, 2015 03:59 PM
smbenoit_79
Feb 2, 2015 01:35 PM
