150hp nozzles
Old Aug 23, 2015 | 08:04 PM
S2masse's Avatar
Default 150hp nozzles
Hey guys how bad would it be to put 150hp nozzles in with stock turbo when I bought it I was told it had bigger internals but I haven't check but I plan to but if not would it be bad to run them with a stock turbo
Old Aug 24, 2015 | 04:20 AM
Jet A Fuel's Avatar
It would be like putting a Holley 1050 dominator on a stock 305 Small block chevy.
It will not be a good idea at all. If you want a good injector that works with a stock turbo look into the RV275 style injector. about 50hp is all i would go bigger with a stock turbo.
Old Aug 24, 2015 | 06:43 AM
S2masse's Avatar
Ok thank you that's pretty much what I heard but I wanted another opinion on it thank you for the help
Old Aug 24, 2015 | 07:34 AM
Jet A Fuel's Avatar
Your welcome glad to help. I like the BD super B turbo from all the reviews I've read it is a great all around upgraded turbo.
Old Aug 31, 2015 | 06:10 AM
gh0stman's Avatar
You would be fine with 150's on a stock turbo. But only is you have all the supporting mods. Lift pump, trans, gauges. Also you will need to get the injectors pop tested after the nozzle swap. But if you don't have any other mods done to the truck I wouldn't worry about nozzles until those were taken care of.
tbreddiesel
Thoroughbred Diesel
Mar 9, 2015 11:02 AM
hardeercy
Nov 23, 2014 04:20 PM
scottxmorris
5.9L 24V Performance
9
Oct 2, 2014 01:59 PM
