Alligator Diesel Performance Visit - Alligator Diesel Performance
Diesel Power Source Turbos
Old May 19, 2008 | 04:02 PM
Alli_Gator's Avatar
Site Sponsor - Alligator Performance
Default Diesel Power Source Turbos
Just letting everyone know that we are dealers of a new line of turbo kits. Diesel Power Source has a couple of options for twin turbos for 3rd Gen Cummins trucks
1st, an economy version using the stock turbo and HT3B as the bottom turbo. This kit is good for about 60 PSI and with 70 SPI of Drive Pressure. This kit is good to up to 600 hp, lowers EGT's between 250 and 400 degrees and won't break the bank. You only use the stock oil return, no need to pull a plug out of the block for a second return for easy installation. These kits come with everything you need to install, including a 3 piece pulse manifold, Hugh air filter, clamps, silicone hoses for a direct bolt in installation. Head Studs are recommended for this application.
The upgraded version uses their Polished D-Tech (HTB2 type) turbo (62/12) for quick spool up and the bottom turbo is HT3B. This set produces between 55-60 PSI of boost and 50-52 PSI Drive Pressure, and lower's EGT's between 300 and 600 degrees. This kit is good to around 800 hp. Head Studs are recommended for this application and it comes with everything you need to install just like the economy kit.
Aslo available for 2nd and 3rd gen is the D-Tech 62/12cm replacement turbo with a polished compressor, handles up to 550 hp and spools like stock. It also has an upgraded shaft so no more breaking turbos. A great deal at at far less than comparable II or HTT.
PM me for more pricing and any more details.
Old May 20, 2008 | 04:17 PM
DB Admin's Avatar
Banned
Any Photos?
Old May 20, 2008 | 07:03 PM
Alli_Gator's Avatar
Old May 20, 2008 | 07:50 PM
DB Admin's Avatar
Banned
Cool Thanks !
Old Aug 25, 2008 | 08:34 PM
bh10's Avatar
PM sent
May 10, 2015 10:57 PM
May 7, 2015 11:50 AM
May 7, 2015 01:40 AM
May 6, 2015 03:20 PM
May 6, 2015 05:11 AM
