95 ram 2500 Gauge loss.
Old Aug 4, 2015 | 08:44 PM
Diesel_Dad's Avatar
Default 95 ram 2500 Gauge loss.
Out of the blue my rpm and odometer stopped working. My voltage meter which usually sits at 14v running but now is at 8v. I replaced the alternator, and got my gauges back for a min or two. So I had thought the alternator was a bad remanufacture, but at the parts store tested ok. I exchanged it for another one and installed only to still have no gauges.
Is there anywhere else I can look to solve the problem? Maybe a relay?
Old Aug 5, 2015 | 04:44 AM
Jet A Fuel's Avatar
Default 1995 Dodge instrument cluster Diagram
Check battery voltages would a good first step.
Both of the items you are having trouble with are controlled by the PCM.
The speedometer will be a white/orange stripe wire at the PCM plug. The tach will be a gray/blu stripe wire at the plug check these pins in the plug for condition.
do you have any other items on the instrument panel that are not working? ie fuel,temp, oil press gauges etc?
here's a schematic
instrument-cluster-instrument-cluster-circuit-1-of-1.pdf
Hope this helps
Old Aug 5, 2015 | 11:54 AM
Diesel_Dad's Avatar
My oil pressure, Temp, and Fuel gauges still work. its just my speed and rpm that don't.
and my voltage meter is low. I will try tracing said wires to and from the PCM.
Thanks for helping give some advise.
Old Aug 5, 2015 | 04:58 PM
JBearSVT's Avatar
Check your grounds too, I've had this happen with bad connections.
Old Aug 5, 2015 | 05:42 PM
Diesel_Dad's Avatar
The link you provided will not open.
I will also check grounds, any certain location I should start?
Old Aug 14, 2015 | 06:03 AM
Jet A Fuel's Avatar
Any updates?
Old Aug 17, 2015 | 08:54 PM
Diesel_Dad's Avatar
Still have not solved the issue.
Old Aug 18, 2015 | 11:50 PM
Jet A Fuel's Avatar
what have you tried so far?
Dec 29, 2014 10:20 AM
Nov 24, 2014 08:20 AM
Oct 24, 2014 02:50 PM
