Pop at idle
Old Jul 22, 2015 | 09:48 AM
MechanicalDiesel's Avatar
Default Pop at idle
I just recently installed a set of 5x0.018s and an afc cover plate. When I started my truck it had a pop while it was idling, granted my idle was below 500rpms. But after I raised my idle back to around 800 it still was doing it only at idle. After it warmed up it seemed to have gone away. Is this just because of the bigger injectors? Or is there possibly another issue?
Old Jul 22, 2015 | 01:17 PM
4x4manonbroke's Avatar
when you add larger injectors your adding timing as the bigger injects more fuel sooner in the total rotation of the crank ...
might try pin timing your Ip and creep up on timing slowly as a way to tune it out .. Most likely the "Pop" your hearing is in fact the ignition of fuel .
Old Jul 27, 2015 | 06:18 PM
wpg6.5's Avatar
you may just have retarded timing. high timing isn't usually an issue. like 4x4 said check your timing.
Old Jul 28, 2015 | 02:01 PM
the only other issue I would think could be an issue is Overall fuel pressure as that's what's pop's the injectors ..
Old Aug 3, 2015 | 04:06 PM
I haven't had a chance to work on my truck again, but the timing was set at 16.5* and it hasn't seemed to slipped yet. Fuel Pressure is good I have it set around 45psi. Maybe 16.5* of timing is to low for this big of injectors. I have to take another look at it the next chance I get.
Old Aug 11, 2015 | 08:14 PM
I would start at factory Ip timing and go from there .. you may find its much easier to creep up the timing than making big increments ...
jordanokc
Feb 8, 2015 03:59 PM
cdetterer
Jan 21, 2015 10:47 AM
Supremedragonx
Dec 17, 2014 07:48 PM
cdetterer
15
Dec 8, 2014 08:46 PM
JMC23
5.9L 24V Performance
Oct 28, 2014 11:03 PM
