pmd box getting really hot after 5 min of idling
Old Jul 5, 2015 | 08:51 AM
98suburbandiesel6.5l's Avatar
Default pmd box getting really hot after 5 min of idling
98 6.5l turbo and i relocated the pmd box to behind the front bumper and it worked great for about 2 years then it went bad with no symptoms. i just replaced it with a new one i have the #9 resistor in it the burb is bone stock. the injectors were replaced not to long ago. i put the new pmd on and let it hang and it started and ran like normal for 5 min then i shut it off and went to install the pmd and it was to hot to touch. i no they get warm but not that hot. so i m wondering what may cause this. the pump inline was replaces a couple months ago. didnt no if any one had this problem before. any help would be nice.
Old Jul 6, 2015 | 08:19 PM
guyina4x4's Avatar
you say "let it hang?"
it needs to be on a heatsink or it will burn up pretty fast.
Old Jul 8, 2015 | 10:07 AM
Default let it hang
Yes I just let it hang so the at if it wasn't the problem then I wouldn't have to amount it it was no where near the engine I normally have it on a heat sink but dosen t seem right to be that hot when just idling
Old Jul 8, 2015 | 10:46 AM
guyina4x4's Avatar
I'm no pmd expert but I believe it is made of transistors, the engine speed should have no or little effect on pmd temp.
Trust me, it needs to be on a heat sink all the time. Idle or full throttle.
Old Jul 25, 2015 | 03:25 PM
InheritedDiesel's Avatar
You still need to put it on a heatsink.
petew
Jul 2, 2015 05:40 PM
