truck stuck in limp mode
Old Jun 26, 2015 | 04:48 PM
Daniel Leipart's Avatar
Default truck stuck in limp mode
I have a 1998 c3500 with an 4L80E I had the truck go into limp mode and I pulled the codes p0758 and p1860. I just replaced both A and B solenoids and filter. checked the voltage at the fuse, ignition (on the white wire) and at the pass-through plug on pin E all of which have 12+ volts. the truck still has the same issues and I dont know what or where to check anything else. also I replaced 2 ground straps and added 2 more grounds one from the battery to the block and one from the transmission to the frame. previously I had a similar issue and dont remember what the codes were but i had put a small ground wire to the tranny from the frame and it cleared up the issue, it doesnt seem to be the case this time. also i swapped computers and I swapped pmd's and nothing has cleared it up
Old Jun 28, 2015 | 12:16 AM
Dieselhead6.5's Avatar
check the harness going to the trans very carefully, there have been a lot of issues with wires breaking but you cant notice it all the time just by a visual check because the sheeting doesn't break. good luck
Old Jun 28, 2015 | 02:42 PM
It ended up being the wire connection that went through the firewall under the dash by the fuse box. works great now. thanks for all the help
Woodsracer
Ford Powerstroke 2011-Up 6.7L
Jul 30, 2017 09:14 PM
Gm3500
May 7, 2015 11:01 AM
ClintD.
Chevy/GMC Duramax 06-07 LBZ
Mar 23, 2015 04:37 AM
syctaz
Mar 3, 2015 09:23 AM
To fast
Chevy/GMC Duramax 04.5-05 LLY
Feb 10, 2015 09:30 AM
