FUEL LEAK!! NEED HELP NOW
Old Jun 20, 2015 | 12:41 PM
collind82's Avatar
Default FUEL LEAK!! NEED HELP NOW
my p pump is leaking every half second it spits a lille fuel right next to the power steering fluid cap. please help fast
Old Jun 20, 2015 | 01:36 PM
collind82's Avatar
after i inspected further i can now see that the leak is coming from the return line after the banjo bolt where the line bolts to the side of the pump right below the #2 valve cover
Old Jun 20, 2015 | 02:38 PM
collind82's Avatar
it is coming from where the line bolts to the pump not the banjo bolt but the we looking one in picture. what do i do? FUEL LEAK!!  NEED HELP NOW-20150620_151719.jpg
Old Jun 22, 2015 | 12:24 AM
97cummins's Avatar
The line could be cracked
or if it's coming from the bolt area you may be able to take the fitting off and try and thread tape it and reinstall.
But if the line is cracked, that means it needs replaced.
Old Jun 22, 2015 | 05:05 PM
4x4manonbroke's Avatar
pull the over flow and go get a new copper washer .. I easy fix
if the line if cracked .. well .. you will have to run a new line( I cut mine short and ran it to the back of the engine with a Bio-Diesel fuel line .. good for B100) ..
Dale9411
Dec 4, 2022 06:51 PM
Dbleo351
Nov 20, 2016 09:34 AM
moneypitk5
Feb 12, 2015 11:01 AM
4x4kingx889
Jan 25, 2015 02:02 PM
Dec 5, 2014 08:30 AM
