tranny late shifting
Old Jun 17, 2015 | 08:58 PM
dieselpowa's Avatar
Default tranny late shifting
Hi guys I got a 95 2500 with 229,600 mi. or so, I recently change the original wheels and tires (275/70/16) for (275/65/18) and now my transmission won't shift as before, now, I Knew this would happened but now it stays at 2000 rpm before it shifts into overdrive and the engine is to loud and I don'y want to hurt it or overwork it. Also I took the truck for atf and filter change and they found pieces of metal in the old fluid, I have the rag with all the metal shavings, all this was done at the dodge dealer, I tried to tell them to adjust the bands and they did not do it, nor did they unplug the battery to try to retrain the memory or tried to see if there was a software update, I know my truck is mostly mechanical. Also would it be wise to try and move the cable that is beneath the throttle? my understanding is that this would lower or raise the shifting from 1st to 2dn and the tps would do it for 2nd to 3rd and overdrive. this is my daily driver and I don't wanna mess it up more than what already is.
thanks. /Users/mariomarquez/Desktop/Dodge.eml/Users/mariomarquez/Desktop/IMG_20150524_090228334.jpg
Old Jun 17, 2015 | 11:16 PM
4x4manonbroke's Avatar
need to adjust the TV cable .. that's your main connection between throttle and trans shift points..
also your speedo sensor and the Transmission control module are not on the same page as actual road speed .. your going to need to have the VSS ( Vehicle Speed Sensor ) dialed in
Old Jun 17, 2015 | 11:29 PM
dieselpowa's Avatar
Thanks for your reply, I know I need to have the speedo adjusted or the miles won't be correct, as far as the other stuff I guess I need to find a shop that would be willing to do it, after all I'm in california and as everybody knows they won't do many of the tricks that other people do in other places. my uncle tried to have his speedo adjusted on his toyota tacoma and no shop or dealer would do it, so now his oil change light comes on about 500 mi. early or (late).
thanks for the advise.
Old Jun 18, 2015 | 12:44 PM
also the stock Valve body isn't worth a crap either .. I bought a SunCoast unit ... SOOOO much better now
fivepointohno
5.9L CR Performance
12
Jan 25, 2016 01:07 PM
Frustrateddodgeowner
Tech Article Submission
Jul 6, 2015 12:33 AM
peterbilt
Chevy/GMC Duramax 06-07 LBZ
Apr 8, 2015 10:33 AM
Ol Goat
Jan 22, 2015 02:16 AM
SixSpeed
Jan 11, 2015 01:41 AM
