lost fuse then lift pump now won't start
Old Jun 6, 2015 | 10:52 PM
bigd.t's Avatar
Question lost fuse then lift pump now won't start
2001 gmc 6.5 Detroit turbo diesel
first the 20 amp fuse that controls the computer blew. then trouble with the anti lock brakes. then lost the lift pump. truck was running great. changed the lift pump and fuel filter and bleed it thru but it won't start,injecters wont open. is this a computer loop,codes not resetting or pdm. how do I check? help! I'm mechanical not a computer wizard.
Old Jun 7, 2015 | 03:54 AM
Jet A Fuel's Avatar
Default Schematics
Sounds like a major power problem to effect so many things. Maybe a short to ground in a wire or component that blew the fuse.
Here are some schematics.
These reference a 2001 GMC sierra 3500 6.6 L diesel. not sure exactly what you have but here ya go.
2001 GMC sierra 6.6.pdf
2001 GMC sierra 6.6 1pdf.pdf
2001 GMC sierra 6.6 2pdf.pdf
2001 GMC sierra 6.6 3 pdf.pdf
Old Jun 9, 2015 | 04:24 AM
HeavyChevy95's Avatar
Find electrical connector for and disconnect fuel heater, look for a short pigtail w/ 2 wires exiting the bottom of the fuel filter manager housing. Not to be confused with the WIF Sensor which has 3 wires..
Replace both ECM 20amp fuses.
Prime and/or purge fuel system.
Try starting nomally again.
good luck
Old Jun 17, 2015 | 02:16 PM
so did it fix itself or what???
landon025
Sep 8, 2015 09:21 PM
Mac1997
Jul 13, 2015 05:08 AM
bigd.t
9
Jun 7, 2015 10:20 AM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
