03 dodge cummins 6 speed rpm spikes
Old Jun 5, 2015 | 03:47 PM
Taylor03's Avatar
Default 03 dodge cummins 6 speed rpm spikes
I have a 03 dodge cummins 6 speed manual that I picked up about 2 months ago it was a one owner off a older couple bone stock when I purchased it and still had this problem. It will typically idle at about 1100 rpms but if I let the clutch out in gear and drop the rpm it will idle around 800 tell I give it gas. It will start to accelerate rapidly when I start sometimes and also likes to jump about 300-500 rpm when I shift at higher rpms. I replaced the APPS sensor with a new one and that did not fix it the new sensor is working great and is in specs. Any ideas what else may cause this? Thanks
Old Jun 6, 2015 | 08:01 AM
dangerous1965's Avatar
Are you feeling this spike? or is it just on the gauge? 1100 is way to high for idle!
Old Jun 6, 2015 | 11:09 AM
Taylor03's Avatar
You can defiantly feel the spike. Especially when it surges off the line you will barely be on the throttle and it will just take off and continue to give it gas for a moment after you engage the clutch. I am going to check my FCA today and see if that is it but I am lost the truck runs and tows great other than that and gets 22mpg around town.
Dertyd
24
Jun 7, 2015 02:45 PM
raude1
Apr 13, 2015 03:38 PM
Josh Chretien
5.9L 12V Performance
Mar 1, 2015 06:00 AM
Linkbeltpower
For Sale
Dec 16, 2014 08:44 AM
jstoshick
For Sale
Oct 2, 2014 10:24 PM
