Rough idle/misfire when warmed up 04 6.0
Old Jun 3, 2015 | 09:34 PM
desperatemofo's Avatar
Default Rough idle/misfire when warmed up 04 6.0
Hi, just pulled the motor on my 6.0. Did the head gaskets with oem ford ones, arp studs, oil cooler and o-rings on all 8 injectors and glow plugs. Got everything back together now and have run the truck multiple times. Every time I start it, it runs like a dream until my oil temp reaches about 115 degrees. Then it starts to chug and a little bit of white smoke comes out the pipe. When I give throttle it sounds/feels normal but I know something is wrong. I monitor all sensors with my edge CTS. All numbers are at par but I keep getting cylinder contribution codes #2,4 and 6 that come and go at different times which is driver side. Please help and i will send you a 6 pack.
Old Jun 4, 2015 | 10:16 AM
saranay's Avatar
check your oil pressure.
and do fuel bubble test.
Old Aug 4, 2015 | 12:25 PM
Crabber0001's Avatar
Check your fuel pump and it might be your fuel tank, if you have not done the Harpoon and Hutch Mods, I recently did mine, the Rubber foot turns to jelly and gets sucked up the feul line then burns out your pump. Just did both of mine. My poor back
bdbfam
Aug 31, 2015 09:06 PM
timracerx
Apr 14, 2015 10:28 AM
scubasteve12
Mar 29, 2015 09:39 PM
jordanokc
Feb 8, 2015 03:59 PM
bizurkhate
11
Nov 14, 2014 12:15 AM
