Key Counts
Old May 16, 2008 | 09:55 AM
vrodrex's Avatar
Default Key Counts
I know that most all programers wipe out the key counts when you install / change programs. What about when you disconnect the batteries? Does this reset the key counts at that time too? What else resets the key counts?
Old May 16, 2008 | 10:01 AM
Wyatt Earp's Avatar
That depends. I have seen it where removing the batteries does and does not. Basically your best attempt should you need to do that is to disconnect the batteries for at least a 24 hour period.
Now the trouble there is that if you are worried about something in particular the short term memory will erase but the long term (accessed only by that STAR reader - about the size of a small car) will find the difference and report a non-conformance. This is seldom done but can be used to void your warranty.
The best programmer out there for 99% worry free writes is the smarty box.
Old May 16, 2008 | 04:12 PM
wildbill's Avatar
Not only do inferior programmers reset key counts, but they can burn the ECM out. Both will void the warranty as we know.
Old May 17, 2008 | 08:20 AM
vrodrex's Avatar
That's what I'm concerned about. I didn't know if I had an issue if there was an excuse for low key counts, other than having a programmer.
Old May 17, 2008 | 02:44 PM
wildbill's Avatar
If you want an awesome programmer that doesn't reset key counts, only one word. Smarty!
Old May 17, 2008 | 02:47 PM
X2
Old May 20, 2008 | 03:18 AM
dalton06's Avatar
so is key counts just turning the key on and off? What's so bad about that?
Old May 20, 2008 | 07:16 AM
wildbill's Avatar
Well if they get reset to 0, they'll know something was stuck in the ECM.
Mac1997
Jul 13, 2015 05:08 AM
thurobred1320
May 5, 2015 09:26 PM
1997silverado
Feb 13, 2015 08:11 AM
Baradium
Nov 21, 2014 08:20 AM
