Power steering issue
Old May 30, 2015 | 08:49 PM
ramrunner01's Avatar
Default Power steering issue
Ok so I know there are tons of threads on this all over the Internet but I want to explain my exact problem cus I always hunt for answers but most of the time no one ever posts they're fixes anyways I put a new power steering pump on the other day because the old one was leaking and at idle I had no power steering well I put the new pump in and everything was working great than today went and drove it and got off the highway after about 70 miles and realized the brakes were really stiff and there was 0 power steering at idle so I came home and tried to bleed the air out of it thinking that maybe it still had air in it and that didn't fix it well than I flushed it thinking it had some crap in there and still didn't fix it where do I go from here? Is it my hydro booster? Or did I just get a junk pump or did I screw the pump up by not flushing it, like I said I still have power steering when I'm moving but at idle there is nothing
Old May 30, 2015 | 10:30 PM
Jet A Fuel's Avatar
Does the power steering pump you purchased match the diesel application?
Or did the parts guy just give you one for a v-8.
Also did the pump come with the pulley on it is it the same diameter as your old one?
Old May 31, 2015 | 09:56 AM
It's the diesel one because they first gave me one for the v8 but it's definitely the right pump and these power steering pumps don't have pulleys they go into the vacuum pump
Old May 31, 2015 | 10:29 AM
Jet A Fuel's Avatar
what kind of condition are the drive lugs on the vacuum pump to PS pump?
Maybe some air still trapped is it noisy?
Old May 31, 2015 | 10:54 AM
Nope not noisey at all
Old May 31, 2015 | 10:20 PM
Ok so here is an update I replaced the power steering pump again with another new one didn't fix it so replaced the hydro booster brakes feel great and power steering feels great except I still can't do full turns at idle so I flushed the system again and still have no power steering at idle could it be my tires are to big for the pump? I'm running 36/12.50/17s
Old May 31, 2015 | 10:26 PM
I mean 35/12.50/17 not 36 my fault
Old Jun 1, 2015 | 12:10 AM
Jet A Fuel's Avatar
Set your self up some grease plates and pull the truck onto them and try it.
Antwhite19
Aug 23, 2015 06:07 AM
krg3590
Mar 15, 2015 08:57 AM
1MooseheadPlease
Oct 13, 2014 05:33 AM
sweetv8s10
Oct 7, 2014 09:47 PM
