fuel filter- change how often?
Old May 28, 2015 | 12:13 PM
michaelascummins's Avatar
Default fuel filter- change how often?
I'm still new to owning a diesel and I've read idk how many different things as to how often to change the fuel filter ranging from 3k miles to only once a year. What do you guys do?
Old May 28, 2015 | 05:05 PM
scottw1513's Avatar
I change mine every oil change, regardless if it needs it or not. I usually run about 10k-15k miles on it.
Old May 29, 2015 | 09:23 AM
dangerous1965's Avatar
Every other oil change will work. It's not a good filter to begin with "Main reason for Injector failure"! Everyone should install a 2 micron filter before the CP3 to extend injector life.
Old May 29, 2015 | 06:57 PM
Regcabguy's Avatar
Baldwin PF7977 5 micron drop in @ 10K. I also have a GDP underhood Cat filter. Change that @ 20K.
On the frame I have a Cat water separator filter. 20K on that.
Whew!
If anything gets past that it was meant to be.
Old May 29, 2015 | 07:15 PM
Whew!
AMEN BROTHER!
Old May 31, 2015 | 09:16 PM
CumminsCoalRoller24/7's Avatar
I use a wix paper filter and change it every other oil change- so about 12k miles. Not to steal the thread but what's the best filtration system for the $$$? This a decent dual filter system?
http://m.dieselfuelfilterkits.com/?url=http%3A%2F%2Fwww.dieselfuelfilterkits.com%2F# 2786
Dbleo351
Nov 20, 2016 09:34 AM
jeffersonl
Nov 15, 2015 07:35 PM
Collin Dow
Feb 21, 2015 08:18 PM
moneypitk5
Feb 12, 2015 11:01 AM
jeffersonl
Oct 25, 2014 06:46 AM
