oil gauge, engine temp and tach dont work suddenly
Old May 27, 2015 | 05:58 PM
JDurks2's Avatar
Default oil gauge, engine temp and tach dont work suddenly
Everything was good on my way to work. Start up the truck on my way home. they aren't moving at all. what could have caused this. 98.5 dodge 24 valve Cummins. Automatic
Old May 27, 2015 | 06:21 PM
JDurks2's Avatar
Default and....
My abs light turned on
Old May 28, 2015 | 02:34 AM
Jet A Fuel's Avatar
Start with the easy stuff fuses inside cab and out. Then check connections at PCM.
Any Mods or just stock gauges?
Old May 28, 2015 | 07:16 AM
JDurks2's Avatar
No mods, stock everything except a small lift and fog lights
Old May 30, 2015 | 04:08 AM
Jet A Fuel's Avatar
Any updates?
Old May 30, 2015 | 10:25 AM
JDurks2's Avatar
Went to start it up after a bit, everything worked. Didn't mess with anything. Super weird
Old May 30, 2015 | 10:42 AM
Jet A Fuel's Avatar
Is your truck a 5 speed?
Old May 30, 2015 | 10:46 AM
JDurks2's Avatar
Automatic, 322,000 miles. My abs light is on now. Gotta figure what's up with that
Old May 30, 2015 | 10:48 AM
Jet A Fuel's Avatar
I found some wire chaffed one time near the clutch pedal on a 1999 manual trans 3500. Not sure if it relevant in your case.
Old May 30, 2015 | 10:49 AM
JDurks2's Avatar
Thanks, I'll check it out
