make my auto trans stronger
Old May 27, 2015 | 05:33 PM
kydieseltech's Avatar
Default make my auto trans stronger
I recently bought a 3/4 ton 4x4 truck with a auto trans just turned over 80k on the odometer I'm not having any issues with the truck at all but I have absolutely no trust with automatics I don't want to do a rebuild or build just prolong the life of one in it whay are yalls suggestions I don't really want to pull the trans but If I need to I will
Old May 27, 2015 | 06:51 PM
JDurks2's Avatar
No idea. But following this one
Old May 27, 2015 | 06:55 PM
Forgot to let yall know that this is just gonna be a DD and hauling a gooseneck horse trailer maybe twice a month only mods will be bhaf 5in turbo back exhaust and fass fuel system
Old May 27, 2015 | 08:21 PM
chuffysplace's Avatar
I don't know of any easy fixes. I've heard that if you add a better torque converter and valve body, that will go a long way (approx 400 hp). At that point, the trans is out of the truck though, and if so, if budget allows, maybe add more such as a billet input shaft, clutch upgrades and internals. I ended up biting the bullet, I figured do it once and be done...I had Tim at TRE diesel do mine. Impressive. It shifts firm but doesn't slip anymore! Home Page Tim's a great guy, he'll work with you too.
Old May 28, 2015 | 02:45 AM
Jet A Fuel's Avatar
What Chuffy said is ideal
Somethings that helps extend the life of an automatic tranny that is fairly cheap and an add on is :
a deep fluid pan and an external cooler.
An inline filter in the cooler return line.
Anything to reduce the heat of the fluid this is what kills transmissions.
The in line filter just keeps contaminates out of the main filter if the converter or clutch parts disintegrate.
Hope this helps
Old May 28, 2015 | 05:00 AM
gh0stman's Avatar
Yes at a minimum a VB and TC are best. If power is increased it is best to look at a kit from revmax or suncoast.
DieselDan_5.9
Jul 30, 2015 07:05 AM
Beau_Jacques
Jun 26, 2015 12:17 PM
apehangerjoe
Mar 26, 2015 03:01 AM
countryboy040993
22
Nov 12, 2014 11:25 AM
UC Kid
Oct 23, 2014 05:29 PM
