6.5 turbo waste gate sticks open
Old May 26, 2015 | 10:52 PM
timmyd's Avatar
Default 6.5 turbo waste gate sticks open
My waste gate has been getting stuck open . so I looked into it and I see guys building these spring loaded turbomaster things . they talk about 2 or 3 pounds of boost and then cranking it up to 11 pounds . now is this tention on the spring or is that boost psi ?? Factory turbo on mine produses at least 15 psi because it burys my gague there. I have a chip , cold air , 4 inch straight pipe , 3 inch crossover pipe egt gague and boost gague . Not that it really makes a difference . do these turbo master set ups work good ? Or am I gonna blow my bottom end out ?
Old May 27, 2015 | 02:58 PM
timmyd's Avatar
Wow ! This site is dead. Anyone recomend a diesel forum where I can actually get some help ??
Old May 31, 2015 | 10:06 PM
1997silverado's Avatar
The turbomaster design (personally You'd be better off to make one than buy the factory one) works and is a must if you're playing with your fuel but it takes a little playing around to dial it in just right. But you wouldn't be on here if you weren't willing to tinker. If you turn it up too high it has a safety mechanism built into your boost pressure sensor (the one that your computer reads and I'm not sure that's the right name) that will put you into a limp mode so you can't do any damage. I've done it quite a few times on my 97 you have to shut it off and restart to clear it and go back to normal operation. Overall fairly safe. Mine shuts me down if I hold 15 psi very long at all. And if anyone knows how to bypass it I'd love to know how
Old May 31, 2015 | 10:08 PM
Your chip might effect the safety though if you're already burying into 15 psi with a factory waste gate controller.
Old Jun 7, 2015 | 04:36 PM
racer55's Avatar
you would be better off finding the vacuum leak,or replacing the boost solenoid/vac pump-which ever is faulty.
Old Jun 8, 2015 | 11:35 PM
UC Kid's Avatar
I would check the vacuum at the waste gate and the waste gate solenoid valve.
Original_big_rod
Aug 21, 2016 02:30 PM
six speed
Sep 14, 2015 09:19 PM
klein444
Feb 27, 2015 01:53 PM
greatlakes diesel
Feb 13, 2015 09:55 PM
Snoobly
Dec 11, 2014 11:59 AM
