Unlock Engine 05 F350 6.0 with 148,000
Old May 24, 2015 | 10:52 PM
jirwin1960's Avatar
Default Unlock Engine 05 F350 6.0 with 148,000
Had a ford mechanic replace head gaskets bullet proof it and EGR less the engine about a month ago. Ran great till last evening appears 1 or more injectors stuck open - changed oil and put in 2 quarts of Hot Shot Stiction Eliminator. Started up smoking real bad but idled about 2 - 3 minutes then flooded. Let it sit for a few minutes - it started again, loaded up then some diesel fuel came out of exhaust into a bucket. Let it sit a little bit - started again and ran a couple of minutes. Tried to start 1 more time, it hit a couple time and then it seems to have locked up. How do I get it unlocked? I have heard taking out the glow plugs and relieving the pressure will do this.
Any help would be appreciated - hope I have not toasted the engine?
Thanks
Russ
Old May 25, 2015 | 10:17 PM
jirwin1960's Avatar
Managed to get the driver side glow plugs out and it now cranks so now comes the fun part trying to determine which injector is stuck. A lot of fuel sprayed out the front cylinder only. Is there anything I can put in the cylinders to possibly free the injectors?
Old May 27, 2015 | 04:53 PM
saranay's Avatar
You have to remove that injector and inspect it.
Dont try to crank up the engine again. You might get hydrolock.
burndiesel
10
Feb 7, 2023 01:15 AM
Cavnar
Sep 9, 2015 07:18 PM
smbenoit_79
Feb 2, 2015 01:35 PM
dieselbomb
Dec 19, 2014 12:08 PM
angies04
Sep 29, 2014 04:11 PM
