Fass pump high pressure
Old May 24, 2015 | 05:46 PM
ramrunner01's Avatar
Default Fass pump high pressure
Ok guys so I acquired a fass stock replacement pump for my 01 the truck has an edge juice with attitude and straight pipe that's it. Well installed the pump and started it up and the truck ran great only thing I'm noticing is I have really high fuel pressure I noticed this before I changed the pump before I changed the pump I had 23 at idle now I'm at 30 psi at idle my question is why is it so high and how can I bring it down
Old May 25, 2015 | 04:26 AM
Jet A Fuel's Avatar
check your wiring first because the pressure transducers are resistance sensitive. I believe the fass pumps have pressure regulator springs that you change out for different pressures.
Here is a link
Old May 26, 2015 | 04:08 AM
gh0stman's Avatar
Does it have an adjustment **** on the side of it? You might want to turn it down.
Old May 28, 2015 | 02:44 PM
No adjustment I actually found out I have 2 pumps one in the tank and the one on the block so I ordered a draw straw and some new hose and am going to get rid of the in tank pump
Old May 30, 2015 | 04:19 AM
Jet A Fuel's Avatar
Cool thanks for the update the cartridge in the tank should just be a fuel sender unit no pump that i know of on a 2001 in the tank.
I only know about the block lift pump.
Your tank should look like the pictures below
Let me know if you find something different You have me curious now!!
Old May 30, 2015 | 08:43 PM
Well I got my new lines and relocation kit today and Iam just waiting on my draw straw the weird thing is is that I can hear a pump back there and I can feel the vibrations on the tank
Old May 30, 2015 | 11:00 PM
Jet A Fuel's Avatar
There are return lines and pickup tubes in there but the wires going to the tank are for the sender unit. Double check how many wires you have back there going in the tank shoud be three only + and - for the sender and a ground for the housing.
Old Jun 3, 2015 | 05:27 PM
Well got it fixed got me a draw straw kit and a relocation kit from fass and dropped my tank and sure enough there was a fuel pump in there removed the pump and installed the draw straw and everything is good to go now 18 psi at idle now 15 wot
Old Jun 3, 2015 | 10:43 PM
Jet A Fuel's Avatar
I believe you, it had been so long since I got rid of that system on mine I forgot about the junk pump in the tank. sorry my bad.
Old Jun 4, 2015 | 03:34 AM
gh0stman's Avatar
Good Deal Man.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
veggyoilkid
Nov 10, 2014 12:39 PM
