99 dodge 2500
Old May 18, 2015 | 09:04 PM
Tomoad's Avatar
Default 99 dodge 2500
My vp44 recently went out. So I got another one from DAP and a set of 75 hp injectors. It has the stock turbo and I have a van aaken can bus box I bought in 2001 I haven't installed the pump and injectors yet but plan on doing this weekend. I also got a bd elbow boost. Do I need a boost fooler? If I put all of this on will it set off a engine light?
Old May 19, 2015 | 04:08 AM
Jet A Fuel's Avatar
First of all Welcome to DB
No it should not cause any engine light.
Important!! I would suggest a upgrade of the fuel lift pump my VP44 has almost 300000 miles on it and I attribute this to never having a cavitation issue ( good boost pump pressure) Air dog . Just be carefull you don't ruin a new pump because of a weak lift pump.
You shouldn't need a boost fooler i can push 35 inches and i am only running an edge EZ.
Have fun building this weekend if you need any help i have some picture of the injector installation and stuff.
Old May 19, 2015 | 11:33 AM
Tomoad's Avatar
thanks Jet, I did put a Air Dog Rapture 100 on about 2 yr ago, I usually run 18 psi at idle and never seen it below 11 psi wot. I do pull a camping trailer and there are some big hills in my area, I need to get me a pyro, because now I will be worried about my egt's. I put a bd exhaust brake on two yr ago also, it has the thread port, Don't know what size hole it is, but I know it has a place for a probe, which gauge kit will work? AutoMeter
Old May 19, 2015 | 10:22 PM
Jet A Fuel's Avatar
Yes AutoMeter is a good choice I believe it comes with the 1/4" pipe plug check with some of the vendors in here they can tell you for sure.
Tony at Mighty Diesel - Diesel Performance Parts For Cummins , Powerstroke , Duramax And More is a very helpful guy and is usually able to answer most any part question.
nelly559
Feb 2, 2015 08:19 AM
Dec 29, 2014 10:20 AM
Nov 24, 2014 08:20 AM
Oct 24, 2014 02:50 PM
