Hard or no start mornigs
Old May 5, 2015 | 08:09 PM
Robby21NoGlowPlugs's Avatar
Default Hard or no start mornigs
I recently bought the truck and it wouldn't start with a shot of ether. found a fuel leak fixed it started fine. Lawson injector and had a weak one on the return side replace both of them. started and ran fine for a few weeks. now it's having trouble starting in the morning. but some mornings it fires right up. had aftermarket inline filter fuel filter, removed inline fuel filter seem like it ran a little better. tested my lift pump pressure, engine off 10 psi, engine running 5 psi. tested lift pump pressure a week later 8 psi engine off just below 5 engine running. could lift pump be the problem?
Old May 5, 2015 | 08:23 PM
dangerous1965's Avatar
Partly lift pump but no start is a sure sign of low compression So you tested all the injectors? And replaced two of them? Feed tubes tight? No fuel in the oil?
Old May 7, 2015 | 11:05 PM
Changed feed hoses and drilled out holes a little bigger on banjo bolt on inlet side of injector pump. Been starting fine since.
Old May 9, 2015 | 02:18 PM
Bigg Redd's Avatar
I would lean more towards the liftpump myself, but if it worked, then cool! I wouldnt rule out a possible liftpump in the not so distant future tho.
Old Jun 15, 2015 | 11:44 PM
GasItOut's Avatar
Default wont start without ether
Im having similar problems as it wont start without ether. you guys think injectors would be a logical place to look next for me? I have a raptor fuel pump.
https://www.dieselbombers.com/12-val...-under-1k.html
Old Jun 19, 2015 | 11:15 AM
rodbuilder's Avatar
Keep using either on it and you won't have to worry about it running!!!!
94turbostroker
Feb 26, 2016 07:51 PM
Dcbb93
Nov 30, 2015 10:18 AM
Blanton
Apr 15, 2015 06:29 PM
dfish001
Mar 30, 2015 03:07 PM
trab123
Feb 9, 2015 09:44 AM
