PO122
Old May 15, 2008 | 02:41 PM
Bosshogg's Avatar
Default PO122
Ok fellers I checked the codes in the odo window the other day and I got a PO122 APPS volts low code. So I then proceeded to check it, and found that it was reading ~.462v when the sticker says it should be .483v. I adjusted it and then took the ground cables off the batteries to reset the fault codes and also allow me to reset the APPS. After doing this, installing a new IAT sensor and removing the grid heaters, I notice the power is much stronger on the bottom end with the comp on kill, but kinda weak up top where it was once strong. I now only make 28psi of boost where I was making 36psi. I expected some loss due to removing the grids but not 8psi. I checked the codes again this morning and found that PO122 is back again. Anybody got any suggestions?
Old May 18, 2008 | 01:17 AM
2500HeavyDuty's Avatar
still having this problem?
Old May 18, 2008 | 06:23 AM
Bosshogg's Avatar
Ran the dog crap outta the truck yesterday and saw 34psi. Much better than 28. PO122 is still there though...
Old May 18, 2008 | 09:26 AM
Mr.Krabs's Avatar
I was getting 28 psi,then 32,then 28...had a darn boot leaking
Old May 18, 2008 | 12:01 PM
hmm... well i wouldn't know where to start with getting to the bottom of that code, but here a bump for ya
Old May 18, 2008 | 12:08 PM
Uncle Bubba's Avatar
Are you sure the code ever really went away when you unplugged the batteries and did you un-hook both batteries. Just askin the obvious first since those are the most likely things I always don't think about when I'm doin this stuff.
The other thing I would look at would be pulling all 3 sensors, checking continuity on them and cleaning them if they still check out as good.
Old May 19, 2008 | 01:33 PM
Bosshogg's Avatar
I dont really have a clue as to whats goin on with it now. Everything is set right, and it will make 34 psi, which is acceptable since I removed the grids, and it runs like it used to again. Code is still there, and it was gone when I reset the APPS. I may stop by Autohell and use a scanner to clear it and see if it comes back again.
Old May 19, 2008 | 01:49 PM
Personally I've never been able to clear any codes by unhooking the batteries. But I know others say they have so I don't know if it's just my mixed up truck.
