Hard starting
Old May 3, 2015 | 09:11 AM
joker55's Avatar
Default Hard starting
Group,
My 04 had the CEL come on last week so I got a scanner to check the codes.
All of the cylinders have the same code reading 0261, 0264,0267 and so on (Injector Circuit Low). So I did a FICM voltage test;
With the key on; 49.2
Cycling key; 49.2
Cranking the engine; 45.1
With the engine running; 43.3
The truck still runs like it normally does, same throttle pickup, same fuel mileage, runs smooth.
The only thing that has change is when I first start it.
When I turn it over to start it either just catches and starts or doesn't the first crank, when I crank it again it starts right away like normal.
Just wondering if the FICM is going out or it is something else.
The truck has only 150k miles on it.
Thanks for the help,
Old May 4, 2015 | 07:17 PM
yz450f269's Avatar
I dont know alot, but it seems to be ur FICM voltage is LOW..(the 45 and 43 #)..... check the FICM test page....it gives appropriate voltage values.
Old May 15, 2015 | 10:24 AM
excutioner's Avatar
You need to replace FICM asap or it will fry your injectors.
Excursion73
Oct 27, 2015 05:21 PM
Easton18t
Jul 30, 2015 02:06 PM
gwmeyer
May 14, 2015 12:46 PM
91 7three
Jan 7, 2015 09:37 AM
