fuel return line pressure?
Old May 1, 2015 | 04:16 AM
|WYG|SS's Avatar
Default fuel return line pressure?
2002 2500 just curious what the pressure is on a fuel return line to the fuel tank. Mins rusted. I got 4in section of line after the T on the back of the block. Looking to just run a rubber fuel line from that to the section of good line on the frame rail. Can't afford the new line right now so just a short term fix
Old May 7, 2015 | 04:57 AM
gh0stman's Avatar
I doubt you have to worry about high pressure through the return line. If the stock pressure is between, lets say, 15-20 PSI, you can imagine that it will be much less. The inner diaphragm of the vp opens at 14psi to send fuel back to the tank. I think you would be ok putting in a piece of regular fuel line with clamps on either end.
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
|WYG|SS
Apr 28, 2015 03:59 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
