intermittent batt light
Old Apr 30, 2015 | 11:57 PM
yz450f269's Avatar
Default intermittent batt light
Hi...early 04 6.0 i have a intermittent battery light situation.... cold or hot..tends to be on more during freeway driving than in town..but still comes on during both....sometimes it flickers on and off....sometimes sustained on and off.. NEW positive battery cable... grounds seem to be good... altenator tested at oreilys....13.4v at idle...no accs on. I just dont want to fry anything.... what should i be checking next?.... thanks
Old May 4, 2015 | 10:25 AM
yz450f269's Avatar
Ok....I bought two new Optima red top batteries. ...800cca.... battery light STILL coming on..... a couple of tests on alternator...one said bad diode..same test...says ok..... soooooo......whats next....alt?
Old May 10, 2015 | 05:30 PM
Powerstroke_steve's Avatar
That's exactly what it is. Does your truck have the dual alternator set up? My truck did the same thing and it wasn't until I replaced the top alternator that I fixed the battery light problem
Old May 10, 2015 | 11:50 PM
yz450f269's Avatar
Single set up, almost positive.........what was weird.... i was driving at night, been trying to avoid it...abit paranoid....so lights are on...battery light was not on as long as running without lights.. i did order a new alt. 185amp..... what would the differences be...between the top alt on a dual alt setup....versus the single setup alt.
Old May 11, 2015 | 10:16 AM
to be honest with you i have NO idea why some trucks have one alternator and others two. All i know is when the voltage drops below (i believe my mechanic told me 10 volts) the battery light will come on. I'm sure that will fix the problem.
burndiesel
10
Feb 7, 2023 01:15 AM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
akSam
15
Apr 5, 2015 01:23 PM
yams
Dec 7, 2014 12:51 PM
